G
gb359
Have a Marantz CC870 compact disc changer (yes its old now) that will store up to 100 CDs. Problem is when you store a CD into it, it remembers what memory store that CD occupied and puts it there automatically.
No matter what if you put a new CD in the system it stores it in the next available store and sooner or later you run out of space because old CDs that you no longer have in it still have that memory store number reserved.
How can you easily reset the device so that it is back to original as new configuration, so htat when you put a CD in it will revert back to memory store 1.
