Marantz and DVI/HDMI?
Discussion in 'AV Receivers & Amplifiers' started by Evil Ed, Nov 20, 2004.
Tags:
  1. Evil Ed
    Evil Ed
    Sep 13, 2004
    24
    Hi Guys
    The new Marantz SR8500 has 2-in 1-out DVI switching... but their high end DVD player have HDMI outputs... if I bought an 8500 with a matching Marantz DVD player with HDMI out, how the hell does one connect the 2 together? Is it as simple as an HDMI-to-DVI cable? And then my normal DVI cable from the 8500 to my Panny TH42PWD6's DVI port?
    Cheers in advance
    -Ed
  2. recruit
    recruit
    Ed i think you can buy HDMI/DVI converters to connect to you're cables!
    John
  3. martinsurround
    martinsurround
    HI :
    I think you can use the HDMI to DVI cable from DVD player to Amp,than use DVI to DVI cable from Amp connect to plasma,another way is use DVI connection from DVD player to plasma.
  4. Evil Ed
    Evil Ed
    Sep 13, 2004
    24
