Marantz 7400 - Remote won't switch to TV Source
Discussion in 'AV Receivers & Amplifiers' started by Peridot, Nov 2, 2004.
Tags:
  1. Peridot
    Peridot
    Aug 24, 2004
    2,918
    Newport, South Wales
    +287
    The Marantz 1400 remote, supplied with the 7400 receiver, has a nifty feature whereby pressing a source button (TV, DVD, etc.) once switches the remote to control that device, while pressing it twice in quick succession ('double-clicking' as the manual calls it) also switches the actual receiver to use that input source.
    I can get this to work for all source inputs, except 'TV'
    I can't find anything in the manual to suggest that it shouldn't work on the TV input, and was wondering whether this is an undocumented 'feature' or a fault with my remote.
    Can anyone else with this combination of amp / remote get the TV input selected automatically?
    Regards,
    Dermot
  2. dboo
    dboo
    Sep 14, 2004
    28
    I have the same problem with mine. Indeed I have fiddled with the input source menu a few times but still the same problem. I was going to raise the problem on the forum today.
