Marantz 7005 ir extender problem
Discussion in 'AV Receivers & Amplifiers' started by rdundas, Mar 6, 2013.
Tags:
  1. rdundas
    rdundas
    Sep 4, 2005
    2,676
    Grangemouth
    +117
    I'm going round and round in circles in google. I use an mx3000 remote and it controls the marantz 7005 perfectly directly but will not work through the mrf250 rf to ir extender or with another ir extender I have. I believe thi is known problem but haven't fond a solution. I have also tried ir extender cables direct into the ir flasher input but that doesn't work either. Also tried taking a direct cale from a flasher output jack on the mrf250 to the flasher input on the marantz, but no joy.
    I think I read somewhere that an ir emitter needs retired to work with the flasher in on marantz. Can anyone help me with a solution please
    Ray
