Marantz 6200 Help Needed
Discussion in 'AV Receivers & Amplifiers' started by Mwillo, Apr 19, 2002.
Tags:
  1. Mwillo
    Mwillo
    Feb 15, 2002
    139
    Liverpool
    Please help I am quite new to Home Cinema and have just purchased a marantz sr6200. And I have ran into a problem my tv only has 2 scart sockets on the back and was wondering how do i go about connecting the amp up so i get OSD. Please Help Me.
    Mark
  2. Dumfy
    Dumfy
    Sep 25, 2001
    146
    Cardiff, UK
    Assuming that the 6200 is the same as the 7200, you won't need the scart. Just run a single phono cable from the monitor/tv out socket on the rear of the receiver to the input phono on the TV.
    This may be mounted on the front or side and is normally where you'd plug in a camcorder etc.
    The display will then show.
    Dumfy
  3. Mwillo
    Mwillo
    Feb 15, 2002
    139
    Liverpool
    Dumfy my tv is is quite old and does not have any phono connections.
    does this mean i cannot setup my amp properly until i get a decent tv.
    Mark
  4. Ian J
    Ian J
    Aug 6, 2001
    25,630
    +4,906
    I have the same amp and it can only be setup through OSD. If your TV doesn't have any front inputs you will need a cable with phono on one end and a scart connector on the other.
    get the cheapest you can as you only need it connected whilst making adjustments
  5. Mwillo
    Mwillo
    Feb 15, 2002
    139
    Liverpool
    Thanx Ian
    what are your impressions of the amp.. Do you have any setup tips for me.
    cheers
  6. Dumfy
    Dumfy
    Sep 25, 2001
    146
    Cardiff, UK
    Hello Mwillo,
    Ian's post above is the way to go with this if your TV doesn't have any phono av inputs. As he says, just get a cheapo cable as it will only be used for set up purposes and removed when everythings been adjusted.
    The receivers are excellent both in home cinema and audio terms.
    The early models did have problems with popping sounds, of which mine was one, but the later models are fine.
    Enjoy it as I'm sure you will
    Dumfy
  7. Mwillo
    Mwillo
    Feb 15, 2002
    139
    Liverpool
    picked up a phone>scart cable for 4 pound that should do the job.
    thanx to all for your help......
    Mark
