rgl201
I have a 6015 with a 7.1.4 set up. I have a stereo amp for the front right and left driven via the pre-amp out to the separate amp. I also have a center pre-amp out to a separate center amp. I’m using 8 of the 9 amps to drive the left and right surround, two rear surrounds, and four over head speakers. I also have a powered subwoofer driven via the sub pre-amp out. I can hear all 11 speakers, and the subwoofer, so I know all the speakers are wired properly. I have a 77” LG TV. I’m not using the speaker in the TV (or I should say, I don’t want to use it as I have my own surround set up). I connected my firetv to the GAME HDMI input to the receiver. I connected my Apple TV to the Media Player HDMI input on the receiver. I have a single HDMI wire from the TV to the receiver. On the TV there are several HDMI inputs. On the Mirantz there are several HDMI outputs. I don’t think I want to use ARC as I read it doesn’t pass Dolby Atmos. Which HDMI output from the receiver should I use, and which HDMI input on the TV should I use to ensure I’m passing Atmos via the receiver to the 7.1.4 speaker setup? I believe I don’t want ARC at all. But the receiver set up asks me how I’m connecting the audio from the receiver to the TV—there is no option for “none”. And I’m confused by the set up as it prompts me for an ARC set up which I don’t want or need. Can you help with the above?
