Marantz 6010KI/PM7200 fixed gain?
Discussion in 'AV Receivers & Amplifiers' started by Ricky27, Jul 4, 2003.
Tags:
  1. Ricky27
    Ricky27
    Feb 8, 2002
    1,968
    Norwich
    +216
    Hi, will be in the market for a stereo amp soon to go with my Marantz SR5300, looking for much better stereo performance from my CD's.
    Looking at both the Marantz 6010KI SIG/PM7200 amps.
    Do these both have a fixed gain so i can set them up with pre outs from my AV amp?
    Dont want to be adjuting two volume controls everytime when listening to movies etc.
  2. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +9
    Do not think so I was looking at this as an option before I bought the 6100's. At the time (6 months ago) Marantz said they did not do a stereo amp with an AV Input, as the 7200 is new you may want to find out for sure. Give Marantz UK a call 01753 680868 and ask for technical assistance you will be put through to a helpful gentleman who will be able to tell you. Let me know what they say, but I will be gutted if they Do.
    By the way You do not need to adjust two controls every time you change volume, you need to work out the best setting for the Stereo amp with a sound meter (or by ear) put a mark on the dial (or use the 12 o'clock position and adjust the output level in your 5300) you then set it to this position each time you start AV mode, and control the sound via your 5300.
  3. Ricky27
    Ricky27
    Feb 8, 2002
    1,968
    Norwich
    +216
    Thanks for that.
    So if i did get one of these amps are you saying the volume on the left and right channels would rise in tandem with the 5300 surrounds/rears etc?
    Thats all i want it to do.
  4. pwiles1968
    pwiles1968
    May 15, 2003
    773
    +9
    Ok we got there in the end.
  5. nathan_silly
    nathan_silly
    I've had this setup in the past- AV amp left & right pre-out to a line input on a integrated amp, setting to 12 o clock and changing the inputs.
    It's a pain in the ass. Search for a integrated amp with a direct input (some Arcams, Audiolab 8000S/Tag 60IRV, some NAD's)
    You are also going via another pre-amp.. not too bad if the integrated amp is a high quality one... but the budget integrated's pre-amp section isn't anything brilliant.
  6. Ricky27
    Ricky27
    Feb 8, 2002
    1,968
    Norwich
    +216
    Why is it a pain in the arse?
  7. nathan_silly
    nathan_silly
    When you listen to a CD- need to reduce volume and change input.
    Switch over to AV- change input, increase to 12 o clock.
    If you forget to reduce volume next time (when playing a CD) it'll blast out.
    And if you forget to increase volume it'll sound weird.
    I lived with it a few years... enough for me to buy another system to get round this problem.
  8. jhjerpe
    jhjerpe
    Mar 1, 2003
    701
    2
    28
    North London
    +58
    Arcam A85 - AV mode with fixed gain! :smashin:
  9. Hawklord
    Hawklord
    Feb 15, 2003
    3,530
    3
    Aldershot, Hampshire
    +295
    My Arcam A75+ has the same av mode with fixed gain.
    Makes listening to cd's on my arcam cd72t an absolute joy.
  10. mick23
    mick23
    Mar 20, 2002
    801
    uk
    i have to agree with nathans point about remembering to lower volume for cd replay with av+integrated set up.
    i had a85+3802 with cd player connected to a85 using processer mode, another thing is if using a sub connected at low level you LOSE the sub for sterio replay through the integrated amp, which might be an issue for people using small speakers,
  11. pwiles1968
    pwiles1968
    May 15, 2003
    773
    +9
    That is why I went to the 6100's, too lazy for the up/down volume business every time I changed source, plus I really wanted to bi-amp and did not have space or money for two Arcam's I’m very happy now and will stick with this lot (amp stage) unless I come across a spare £2.5K I did not know I had.
