Marantz 5400
Discussion in 'AV Receivers & Amplifiers' started by pclarke, Jan 11, 2004.
Tags:
  1. pclarke
    pclarke
    Hi guys,
    I am interested in the Marantz sr5400 amp. I was wondering if the MS premiere speakers would be a good match. They are rated at 4ohms, however the unit accepts 6-8ohms. I am a bit confused :-(
    Anyone any experience of audio dropout on this amp. I have read somewhere that this may be a problem?
    Is there any other amps I should consider.
    Sorry for all the questions but thank you for your help
    Pclarke
  2. keylion
    keylion
    Oct 13, 2002
    212
    Lancashire
    +9
    Can't answer the speaker question but got this amp last Thursday and have probably used it for around seven hours on an optical connection with no sign of any drop out problems.
    Hope this helps.
    KL
  3. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    hi . I am allso thinking of this amp .I am thinking of getting the OSE version though as it has upgraded electrics over the standard version . I am hopping for the extra £40 that they have solved any small problems that there were with this receiver .
