Marantz 5200 vs 4200
Discussion in 'AV Receivers & Amplifiers' started by jonathanos, Dec 12, 2004.
Tags:
  1. jonathanos
    jonathanos
    I'm looking to buy a used amp to go with a set of 4 mission m72's. It will be used 50/50 for home cinema and music, (mainly dance music via vinyl). Would people recommend the 5200 over the 4200 ? Is the difference just more power?
    Or is it worth paying an extra £150 and getting the 5400 OSE?
    Thanks for your advice!
  2. suicidal_maniac
    suicidal_maniac
    Dec 3, 2004
    58
    I have the 4400 and its a good amp..I cant tell much difference when using it as apposed to my arcam gear...which says alot
  3. ranger1873
    ranger1873
    if you use it 50/50 the best bet is to get a seperate amp for music.
    I have a SR 4200 that i used for both a/v and music, i was never happy with the music side from it. The a/v is great, it is only a recever remember....
    i got around my prob by getting 2x marantz ma6100 power monoblock amps linked up to the pre-out's on the SR4200 to drive my B+W dm601 front's,(brand new on e-bay :rotfl: ) and the sound stage is now great.
    you could do this or got a stereo amp for music like the marantz PM7200.......
    hope this helps
  4. jonathanos
    jonathanos
    Would you think the 4400 is worth an extra £100 over the older 5200? To me it just seems to be a newer DSP chip and the circle surround which I wouldn't use. Any others with advice on the 5200? Thanks
  5. ranger1873
    ranger1873
    If you won't use it dont bu'y it, "well, that's what the wife tells me :laugh: "
    There is a SR4200 on e-bay now @£52 and a PM7200 @£165
