Marantz 5200 question for an owner of
Discussion in 'AV Receivers & Amplifiers' started by Markster, Mar 6, 2002.
Tags:
  1. Markster
    Markster
    Looking at this image:
    http://www.marantz.com/p_product_alt.cfm?id=552&cont=e&line=avr&img_ext=bck
    On the back on the left you have your speaker pre-outs for connecting to an external amplifier
    From this picture it appears to me that the centre speaker (black phono socket) only has 1 phono pre-out?, i.e. it doesn't have a L and R as the fronts and rears do
    Can someone take a quick look at theirs and confirm?
    Thanks in advance for this
  2. Ricky27
    Ricky27
    Feb 8, 2002
    1,970
    Norwich
    +217
    Hi,i think you are getting a little confused here,
    Each channel has 1 phono each,i.e left channel output is white and right channel output is red,each feeding one channel,therefore one speaker.
    As there is only one center speaker used in surround,one phono is all you need
    I hope this helps you.
  3. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    Yes Ricky27, you are correct in the case of the Marantz but some amps now offer the option of two centre channels has some people say this is better for the larger screen.
    I belive this is the same channel split to give the same output to both speakers and is just so they can be set apart a little making the centre stage a bit wider. This could be useful for screens of say 40inch or larger.
    Mandlebrot :)
  4. Markster
    Markster
    Hi Ricky27
    No, there is no confusion in my question.
    Thanks for confirming the Maranatz has one out for the centre
    fyi the yamahas have 2 (L & R) for the centre
    thanks again
  5. mjn
    mjn
    May 24, 2001
    22,264
    Herts, England
    +10,120
    but if you read some posts, you don't even need a centre!!
  6. Markster
    Markster
    the most important speaker in the room imo
  7. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    I disagree as the most important speaker in our room is my wife because if I ignore her I won't get any dinner.
  8. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Which Yamaha? Don't you confuse this with the pre-out for the center rear on Ex/Es amps!? :confused:
  9. mjn
    mjn
    May 24, 2001
    22,264
    Herts, England
    +10,120
    my yamaha 392 had 2 centre speaker outputs, in case you wanted 2 centres.
  10. martian1
    martian1
    Dec 30, 2001
    2,409
    113
    Sunderland
    +667
    I had a pioneer amp rated 60w, this marantz is rated 90w yet i seem to be sucking a lot of juice from it to drive my speakers...]
    I have to crank it up to over 3/4 on dial to really get it kicking in anyone else get this. I also have to set my centre at +8 on speaker level menu.
    Can someone try this and tell me what you think. Put a DTS ES disc on [ T2 or Gladiator] and while amp is set to DTS mode also switch on S.Direct... Seems to give effects a great boost both in detail and power. Can you let me know your opinions..Thanks
  11. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    As does my Yamaha DSP-A1 (two set of terminals) but they were talking about phono (RCA) connectors, thus referring to the pre-outs. So far I haven't seen any amp with two pre-outs for the (front) center channel.
