Marantz 5200 A/D
sceptic
Whenever I switch the the amp into CD mode I also have to hit the Amp and then the A/D button before I can hear anything. :mad:
Is there a way that the amp can be ready for CD playing as soon as I enter CD mode :confused:
Help please
kevb
In the set-up you have to tell the amp if it is using an Analog or Digital input for the signal.:)
sceptic
Thanks for reply.
I've told the amp that CD is ANA (I thought CD was DIGITAL:blush:. It now defaults to analogue which is good :D
So now I have DVD as DIG and
DSS as ANA (I thought CD was DIGITAL too, :blush: :blush: )
Is this right?
Thanks for your help
kevb
Sounds about right.
I use my DVD as a CD player which means I can either output the sound through the amp in DVD mode using the Digital out or using the Analog out and putting the amp in CD mode.
Anything you have that uses a Phono cable should be set to Analog and any Optical or Coaxial cables set to digital. Hope this helps.:)
sceptic
Thanks kevb
Now I understand what I'm doing. :)
