marantz 4200 vs 5200
Discussion in 'AV Receivers & Amplifiers' started by fakebeard, Aug 6, 2002.
Tags:
  1. fakebeard
    fakebeard
    hello again! can you help?
    I have just bought a 5200 for £400 from richer sounds and am wondering (as i am very lame with av gear) is this enough better than the 4200 (£269) to warrant the extra £130? the 6.1 is matrix and i dont realy need the extra power.
    (the demo-monster made me buy it:) )
    take it back or keep it?
    or where can i find an eye bleeding deal that richer sounds will match on either one to make my mind up for me?
    cheers
  2. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    Take it back. I got mine for £360 from a hifi shop. You can do far better than £400!!!!
    6.1 is matrix on DD anyway. You are only missing out on DTS 6.1 discrete (and ne06 and cs5.1 but they are comparable to DPL2).
    I compared these 2 and considered the 5200 to be more flexible with better options for connectivity.
  3. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    I got a SR5200 because it has a 6 channel anologue input so my PC can plug into it.
  4. 2 Point
    2 Point
    try www.avland.co.uk they have the 4200 in black for £239 delivered. I'm well chuffed with mine.
  5. gz5ztg
    gz5ztg
    Jan 29, 2002
    465
    28
    Yorkshire
    +30
    The extra power of the 5200 isn't really worth 130 quid, it is only 20 wpc extra dn this makes even less difference when you consider that the measurement is not linear.
    If you aren't interested in 6.1 then I would suggest getting he SR4200, it might even drop in price further cos of the 3400 coming out in September.
    As for connectivity the 4200 more than satisfies my needs, I guess if you want to plug in a 5 or 6 channel source then the 5200 would be better.
  6. finlab
    finlab
    Jul 23, 2002
    118
    Aberdeen
    I went for the 5200 as I got a good deal 2nd hand.
    It arrived today:)
  7. KevB_UK
    KevB_UK
    Are you sure you paid £400? Sorry but Richer has it on their website for £339.95 !!!
    Take it back kicking and screaming!
    I got an SR6200 from avland.co.uk for £380 a few weeks back, but they are all sold out now.
  8. Pete Callan
    Pete Callan
    Apr 23, 2002
    104
    16
    London
    Last week I bought a Marantz 6200 for £382.19 (delivered next day) from QED website address:www.qed-uk.com.
  9. JIT
    JIT
    Mar 2, 2002
    1,195
    38
    Glasgow
    +8
    What about the new 4300 and 5300 which have EX/ES Discrete and not Matrix like the 4200 and 5200. They are due next month for £340 and £440.
  10. fakebeard
    fakebeard
    Thanks everybody for your input, i have taken it back and got the 4200 for £234 (price match from avland) not sure if it was the right thing to do but my wallet is very happy :D
    it apears they saw me coming.......
    thanks again and seeya in the speaker section :confused:
  11. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Most comapnies run the web site as a different company. Therefore what you see on the web will be cheaper (less overheads). Richer sounds do make this clear, that they may not match web prices
  12. paiger
    paiger
    Jit, do you have any more details on the 5300. I only have 5.1 and the sofa is against the wall so no chance of the 6. ES/EX doesn't really bother me at the mo so the 5200 looks fine. Is there anthing else I would be missing out on?
    S
  13. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    You will be missing out on DTS ES discrete the 5200 provides matrix. DD EX is matrix anyway which the 5200 already does. You will get CS5.1 & DTS Neo6 which are different specs for what DPL2 offers (most people say neo6 is not hot but CS5.1 is better than DPL2).
    If your sofa is against the wall consider KEF Custom install if you are allowed to hack into the plaster (you can cover them in wallpaper matching fabric!!) for the back channel
  14. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    QED!! Next day!!! I ordered from www.audiovisiononline.co.uk and Im still waiting after 2 weeks!!! I ordered the 6200 for £417 so its more expensive as well!!
    Dave
    <edit> I've just cancelled and re-ordered from QED, apparently they have them in stock so should be a couple of days :) HOORAH :) </edit>
  15. Pete Callan
    Pete Callan
    Apr 23, 2002
    104
    16
    London
    CodeThief
    So you owe me a pint! :D
  16. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    *cough* yeah :) Where do I post it ;)
    Dave
  17. Pete Callan
    Pete Callan
    Apr 23, 2002
    104
    16
    London
    Oh I 'll survive on the promise of a pint on the internet freeway some time.
    Anyway, what speakers are you getting with your Marantz 6200; I've gone for Missions: M73 fronts, M7C2 centre, M7DS rears, (M7as sub later). I also have a Tosh 510 DVD and Loewe Vitros 32". All in black, looks cool!
