Marantz 300 series
pcookie
I managed to get hold of a new 2002-2003 catalogue at the HI-FI expo at Heathrow, so maybe a call to their customer services are in order. Basically if you are cosidering buying a Marantz, I would check the new specs before buying the old 200 series. The new series may be more expensive than the older now discounted stock, but the specification is much higher.
D
darren7
tell me what prices you get, I have been told £565 for the 7300, this sound good doesent it?, this is with postage as well.
Where can you find the specs? the web site has the old models on.
pcookie
Specs for 7300 are:
6x 110w 7.1 channel input. DAC 24bit/192khz
Dolby Digital/DD EX PLII DTS/DTS ES NEO 6
CIRCLE SURROUND II SOFTWARE UPGRADE PORT (RS-232)
COMPOSITE IN 5, COMPOSITE OUT 3
S-VID IN 5/ OUT 3
COMPONENT IN 2/ OUT 1
ANALOGUE IN 8 / OUT 4 DIGITAL OPT. IN 3/ OUT 1
DIG COAX IN 3/ OUT 1 PRE AMP OUT 7.1 CHANNELS
MULTI ROOM AUDIO/VIDEO (CVBS/S-VID)OUT
2 DC TRIGGERS D.BUS IN & OUT AC OUTLET 1 UNSWITCHED
FRONT INPUTS AUDIO/COMPOSITE/S-VIDEO/ DIGITAL (OPT)
HEADPHONE OUT. LEARNING REMOTE (NOT TOUCHSCREEN)
Not bad for under £600!
