marantz 1400
Discussion in 'Home Cinema Control & Remote Controls' started by rab4169, Jan 26, 2004.
  1. rab4169
    rab4169
    looking to buy a new remote , marantz 1400 looks good, anybody any opinions on this or any other hard button remote would be helpful.
    thanks
    robert
  2. Gomez
    Gomez
    Cheers,
    I got my RC1400 a few days ago.
    Highlights:
    • Nicely backlit LCD and buttons(blue)
    • Up to 20 commands can be named individually on the LCD for each device
    • Useful hardbuttons (including dedicated play, stop, pause etc. buttons, which the RC1200 didn't have)
    • Strong IR, hence operating distance is great
    Lowlights:
    • Poor contrast of LCD (even though it's adjustable)
    • Poor building quality (cheap plastic IMO)
    • can't learn all of my devices perfectly (it's having problems with my TV and my Set-Top Box)
    • rather expensive for the performance it delivers
    Summary: Good remote with some major problems and way too expensive. If it retailed at half of the price, it would be a recommendation.
    Gomez
  3. cowtipper
    cowtipper
    Jan 29, 2004
    165
    19
    I have owned a rc1400 for abotu 6 month now it is about teh 4th controller i have had which have asloo included a pronto and i must say it is really good for the money mine on ly cost me £50 and it does everythign i have ever asked of it i have never had any of the issues that gomez mentions
