Maranta MM8077 speaker connections
kingcobbler
I am about to move my kit around and the speaker cables are all connected as bare wire to the speaker connection points. This is a right pain and there is so little room, especially when I have bi-wired cable talk 4.2 cable, so the copper barely fits the hole.
Question - can I connect using banana plugs or spades, if so can anyone recommend a suitable set that will accept the required thicknesses of the cable.
exm
Banana plugs work fine in this amp
exm
I recommend getting locking banana plugs
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
