Quantcast
Maplin Wireless HDMI Video Sender
andy1249
This looks like an opportunistic seller grabbing a failed technology and trying to make a few quid quickly before everyone finds out its rubbish.
A bit like Del Boy trying to shift the Eastern European Video cameras !!
This tech was at one time considered and looked into by a few large companies ( Sony being one ) and was quickly dropped because it introduces a huge amount of artifacts. The Picture quality is terrible.
There were two wireless systems being looked at for HDMI , this one works at 5GHz and means heavy compression , leading to lots of artifacts , not the kind of thing expected over a high quality HD interface like HDMI , and has been dropped by all serious manufacturers.
The other one worked at 60Ghz , meaning no compression and a high quality picture , but at that frequency was line of sight only , break that line of sight and the signal was lost , so again , that one has been dropped by all serious manufacturers.
There is no real alternative to cables when it comes to HDMI , this maplins unit is far too expensive given its very very poor quality result.
Joe Fernand
AVForums Sponsor
As andy1249 says even when it works its not great - we have a big box of discarded samples here to back up Andy's assessment.
HDMI over single or dual CAT5/6 is a far better option if you can get the cable(s) installed - they can run externally if need be.
Joe
audiosparks
You should take a look at the Amimon WHDI based products:
Amimon - WHDI Technology Overview
There are a few around, from Marmitek:
GigaView820 - Wireless Full HD Audio/Video Sender - Marmitek
& Gefen:
Gefen, LLC - GefenTV Wireless for HDMI (5 GHz Radio Technology)
Not cheap though at £350++
I've got three of the Marmitek ones, branded AirSync HD (I bought them in the states). Picture quality is excellent with no drop-outs as long as you don't try to beam through 3 concrete walls and travel 60ft! 1 wall @ 30ft or 2 walls at 15ft and you can still get 1080p. They have a boost mode to allow them to send further, but only at 1080i, still perfectly good enough for a bedroom TV. I only use 2 of them, so if anyone's interested I have a boxed one for sale.
Joe Fernand
AVForums Sponsor
They all ‘work’ to various degrees!!!
As samples we have to destroy/recycle them as part of the import process – they can’t be sold or released to end users.
Joe
leamspaceman
Joe
Okay...was worth a shot:thumbsup:
Such a shame you have to destroy them.
Thanks for posting back though:smashin:
Similar threads
