many cables
Discussion in 'Cables & Switches' started by micks_address, Aug 12, 2004.
  1. micks_address
    micks_address
    Nov 29, 2001
    4,520
    83
    Dublin
    +234
    hi folks,
    I had to go through a rewire last night and its an experience i dont want to have to go through for a while! I had to put all my gear in a cabinet so the little fella (18 months) couldnt get at it. Prior to this he would climb up on top of the dvd player and sit on it and press the be jesus out of every button in site. Its all now nicely tucked away i a cabinet i bought from argos
    http://www.argos.co.uk/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=2501&productId=102879&Trail=C$cip=16362>C$cip=16377>C$cip=16378&categoryId=16378
    I have a vcr, x box, ps2 and dvd all feeding into my pj and amplifier. As you can imagine this means loads of cables - video/audio and power cables all dandgling out the back of the cabinet and plugged into exenstion leads/switch boxes.
    When my wife saw all the cabling she asked me if it was safe to have all those cables so close together so i guess thats my question - is it safe to have power cables/video cables/audio cables all bundled together? I only have the power to the cables switched on when i'm using the gear - when i finish i switch off the power at the socket but its still a bit messy
    Any opinions appreciated...
    Cheers,
    Mick
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    It's safe to keep all of the cables bundled together but it isn't best practice sonically. It is best to segregate the power cables from the others to cut down on interference and if their paths have to cross it should be done at right angles. Not always easy to achive though
  3. micks_address
    micks_address
    Nov 29, 2001
    4,520
    83
    Dublin
    +234
    Ian - would you reckon the best approach would be to cable tie all the power cables together in one bunch... then cable tie the audio cables in one bunch and then the video cables together?
  4. mevetts
    mevetts
    Oct 31, 2003
    439
    Ahem....excuse me. Just curious to see if anyone has an answer?
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,237
    The Borders
    +2,940
    micks address
    In theory Yes in practice it can cause as much hassle as it does gains - its not easy getting a tidy layout at the back of a system; unless you have it rack mounted and include cable trays in the rack mounts.
    One point to consider being the choice of Cable ties or a Velcro wrap - cable ties are a pain in the backside if you ever need to get a bit of kit back out of your system; with plenty of opportunity to damage a cable when your snipping ties.
    I prefer to use Velcro strips to bundle cables.
    Best regards
    Joe
  6. mevetts
    mevetts
    Oct 31, 2003
    439
    Joe,
    Would it be better to at least ensure that the mains cables are kept separate from anything else?
    Cheers,
    Mark.
  7. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    Sorry - I missed this one :blush:
    Mark - It is best to segregate the power cables from the others if possible. Not being the tidiest of people I just use string tied in a bow round bunches of cables and interconnects to keep them apart
  8. SimonO
    SimonO
    Nov 4, 2002
    3,193
    71
    Hertfordshire
    +64
    Get it all out of sight and forget about it!!!
  9. mevetts
    mevetts
    Oct 31, 2003
    439
    Cheers.
    Mark.
