Manufacturer's screen
Discussion in 'Blu-ray & DVD Players & Recorders' started by Thomas Conway, Nov 13, 2003.
  1. Thomas Conway
    Thomas Conway
    I've put a DVD player with the 2nd TV and thought about using it for playing CDs thru the TV also. However, when the DVD is playing a CD the screen always shows the manufacture's logo. Is there anyway simple (and cheap!) way round this.
    The DVD player is a Cambridge Audio DVD55.
    Ta
  2. mjcairney
    mjcairney
    Oct 26, 2003
    6,916
    2
    4
    137
    Airdrie, Scotland
    +870
    Cheapest and simplest way is to turn the TV brightness to zero.
    :lesson:
  3. Harry T
    Harry T
    Almost to obvious, but some DVD players have the ability to turn the `video display' off.
    A button on the front panel of my Pioneer performs this task.
  4. Thomas Conway
    Thomas Conway
    Thought about turning down the brightness but I'd to turn down other settings as well and it'd be a pain to reset each time.
    DVD doesn't have a simple 'turn off screen option'.
    Been reading thru some of the other forums and maybe a cheap active sub and sats maybe the way to go.
    Any recommendations for under £200?
  5. mjcairney
    mjcairney
    Oct 26, 2003
    6,916
    2
    4
    137
    Airdrie, Scotland
    +870
    I too have a Pioneer DVD player with a button on the front to turn off or turn down the display, but it's the DVD player's display, not the TV's - I'm not sure that any DVD player gives you the opportunity to turn down/off the TV display.
