Manuel Region Change - Sony 525
Discussion in 'Blu-ray & DVD Players & Recorders' started by adnan77, Mar 7, 2001.
  1. adnan77
    adnan77
    Anybody is aware how to make the manuel region change in this player ? I'm not able to run RCE Disks and I though if I change it manually to R1 then I'd be OK.
  2. Rubberscrubber
    Rubberscrubber
    i got a 725, and to manually chg regions do this :-
    press shuffle,enter,1 ( ie. region required )enter, then turn on player.
    the above is done with player in standy-by.
    if that does'nt work use program key instead of shuffle .
