Manually tune Toshiba 28/YT/56 to digital
Discussion in 'Televisions' started by eddie123, Sep 6, 2005.
  1. eddie123
    eddie123
    Hi.
    Please help.
    I ran the auto tune to set up the built in digital box, but it tells me the signal is poor.
    This TV is a replacement so I know the signal is ok.
    Can anyone tell me how to manually tune?
    Manual is a bit vague.
    Eddie :lease:
  2. JohnW14
    JohnW14
    Aug 6, 2004
    77
    Wiltshire
    If it's anything like the ZT29, you will need to press DTV menu on the remote. Go to Setup. Go to Manual Tune and enter the channel number. By channel number I mean the 'frequency' upon which the service is broadcast, somewhere between 21 and 69.
    It you're not sure of the channel numbers, look at:
    http://www.dtg.org.uk/retailer/transmitters.html
    HTH
  3. JayCee
    JayCee
    Jan 20, 2004
    19,744
    Lanarkshire
    +1,876
    As "johnw14" says find your local transmitter from the link he gave and enter the "Multiplex" number.....there will be 6......it should then add whatever "services" (Programmes) it finds in that multiplex.
