Manual repeat recordings on humax 1010S?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by richard plumb, Jun 22, 2015.
Tags:
  1. richard plumb
    richard plumb
    Jan 27, 2002
    14,551
    Windsor
    +1,056
    i just picked up a HDR-1010S to replace my TiVo box and save some pennies. In the process of moving across season passes, and finding some shows that don't trigger a 'record series' prompt. Does this mean it'll only record the next episode and then stop?
    Is there any way to set up a forced repeat recording - eg every Wednesday at 8pm on C4? most if these shows are on NhK World where I'm getting about a 50/50 success for series recordings.
  2. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,622
    Redditch
    +4,208
    If there is no serial crid codes, you will only get the record programme option, and it will record only once and it will not be in a folder.
    Yes you can add manual repeating recordings.
    Recordings - Planned - press right twice to where it says set recording. Enter the required details.
