Manual or Automatic region change
Discussion in 'Blu-ray & DVD Players & Recorders' started by raven219, Mar 7, 2001.
  1. raven219
    raven219
    Mar 5, 2001
    546
    East Anglia (well someone has to live there!)
    +19
    I am looking at buying the Sony DVP735. As per normal Richer sounds is doing a good deal on a multi-region version. The details say that this is automatic region mod (and not RCE compliant).
    Should I spend a little bit more and get the manual region mod espically as there is good chance that this player might have to go outside Europe in the near future.
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    No matter if it goes outside of Europe or not, make sure it's RCE compatible (ie manual code selection possible) in any case!
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,526
    Somewhere in South Yorkshire
    +5,999
    AFAIK (maybe I'm wrong) none of the Sony mods will play RCE. Suggest Pioneer - they do
  4. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Any player with manual code selection should work ...
    If I can't eat it, drink it or fudge it, I ain't interested.
  5. wiz
    wiz
    Aug 20, 2000
    4,110
    +3,134
    I have a Sony player, works ok with the Paragon mod
  6. adnan77
    adnan77
    Can you guys tell me how to make the manual region change in sony players ?
  7. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    That depends on the modification. The manual change might not even enabled on your player - contact your dealers / company who did the modification to find out if it can be done.
  8. tan1415
    tan1415
    I suggest looking at the pioneer or a toshiba.
    Sony has a lot of trouble with modifications and RCE esspecially the newer models.
    If you insist on a Sony i suggest you checkout the "old" 725 or the 7700.
    manual or automatic.
    I think manual change is a MUST.
    RCE is just new and it will only improve. With manual you can avoid RCE all together.
