Manual / Instructions for panny TYSTPA20 stand
Discussion in 'Plasma TVs Forum' started by Seanjackdan, Aug 18, 2004.
  1. Seanjackdan
    Seanjackdan
    Just received this stand today ( no plasma yet though ) and I was wondering if anyone knows any on-line websites where I can download the manual / instructions as there were no instructions in the box.
    Not having received the tv, it isn't that obvious where the screws / rods go, etc...
    Any help would be appreciated........
    Sean !!!!!!!!!!
  2. 888
    888
    I can send you a PDF tomorrow if you want. Can't remember if the model number matches but my stand for for the 37PA20 or 42PA20 screens.
  3. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    Check out the following thread for instructions for the TY-ST42PX20 pedestal stand. Although not the PA20 stand the principle is exactly the same between the two, only the style and shape are different.
    http://www.avforums.com/forums/showthread.php?t=143652
    The poles should be positioned depending upon whether you are mounting a 37" or 42" screen. The poles screw to the base using the 4x off short bolts. The plasma in then lifted onto the poles and then fixed down using the 4x off long bolts thus fixing the entire assembly together.
    BTW, I got the PDF instructions off the Japanese Panasonic support website, very handy info there ;) Another good site is the USA support website.
    http://service.us.panasonic.com/operman/findmanual.aspx?model=TYST
    They have instructions for the TY-ST50PX20 which is also the same but does not have differing pole positions for different sized screens.
    S.
  4. Seanjackdan
    Seanjackdan
    Hi 888,
    That would be great - thanks very much......
    Will you put it on this thread or e-mail me ??
    My e-mail is "[email protected]"
    again....many thanks....
    Sean !!!!!!!
  5. Seanjackdan
    Seanjackdan
    Steve P,
    Again, thanks for all your help...........
    Sean !!!!!!!!!
  6. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    No problemo :) Good luck with the telly :smashin:
    S.
  7. 888
    888
    Check your in box.
