I've mentioned before on here how impressed I am with my Manhattan T3-R. It's what the Humax Freeview Play devices should have been. I previously has the Humax FVP-4000T and boy was it slow and clunky!
Having used the Manhattan for a few weeks I have experienced no issues at all, but I have found a couple of gems.
The Watchlist is an excellent way to 'store' catchup programmes. Clearly they're not downloaded, but they are all in your watchlist, whatever service they come from. They only appear in the watchlist if you added them from a Manhattan menu, like search. If you go directly to, say, iPlayer, you can't add a programme to the watchlist. Today I discovered that if you go back in the EPG, select a programme you'd like to watch, you can add it to your watchlist from there too. The watchlist feature is the icing on the cake. It's really useful. Only one issue, catchup programmes which aren't from iPlayer can't remember where you were if you didn't watch to the end. I'd say 95% of my catchup is BBC based so it's not a problem for me.
As far as I know Watchlist doesn't have a dedicated remote command. I have a Harmony Hub so created a quick macro to give me a one-button access to the watchlist. Menu > Right > Right > Right > Select. This gets you to the watchlist no matter where you were previously.
The Manhattan hasn't failed me in nearly two months and the feature integration is top class. I highly recommended it!
