Manaul Component Cable Switcher
Discussion in 'Cables & Switches' started by WoodyJ, Aug 5, 2005.
  1. WoodyJ
    WoodyJ
    Aug 5, 2005
    35
    Hi Guys,
    I've recently bought a 32LD7200 and I can now start using component cables.
    I've got myself a profigold component cable for my DVD player and also a PS2 component cable. I don't want to keep pulling cables out of the back of the TV so I want an inexpensive switcher.
    I've just ordered this one for £15 :
    http://www.whitedog.co.uk/catalog/product_info.php?cPath=3_59&products_id=421
    I was wondering though will I lose any quality going through this switcher?
    The profigold cable isn't a cheap one so I don't want the quality of the cable to be cancelled out by a box in the middle.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,109
    Rainham Essex
    +2,381
    TBH the switch you linked to does look cheap, and I would therefore think that any benefit of good quality cables will be lost with this. All I can really suggest is that you try it and see if the PQ is good enough for you.
    If you find the PQ is not good enough then I would recommend you get one of These as it will not reduce the PQ too much. At £55 it is a fair birt more than the other switch, but IMO you do get what you pay for.
    Mark.
  3. WoodyJ
    WoodyJ
    Aug 5, 2005
    35
    Thanks for the reply. The £15 switcher came on saturday and to be honest I can't notice any change to the picture quality. DVDs still look razor sharp so I'm happy.
