simo2004
Established Member
Hi all
Thought id drop in and get some advice and document my man cave..
The room is 5m x 3m currently been stripped ready to be plastered etc will have a 100” screen and a bar in there with a juke box etc
Equipment I have for the room is
Monitor audio CT165 ( only if I can get some Grills to cover the hole in the celling in the front room does anyone know where I can source these please ?
KEF Q500 & KF Q700
DENON AVRX3300
For projector I was always going to go with the HD141X but the shop is telling me I should go for a BenQ W1050 I know nothing about projectors so will need some input here.
The screen I already have is a cheap 100” electric screen by homegear which I have yet to fit
Projector will be used mainly for films but also the xbox.. there will be little back ground light other as the doors are blacked out
So I guess for now I need to decided on the projector or other suggestions and find come grills for the CT165
Ian
KEF Q500 & KF Q700
DENON AVRX3300
Ian
