Mallrats & opinons on Toshiba SD210E
Discussion in 'Movie Forum' started by Chandler, Nov 21, 2001.
  1. Chandler
    Chandler
    I was wondering if anyone could help mallrats is coming out R2 on 17/12 for £10 but does anyone know if it will have all the special features (& easter eggs) and the audio commentary like the R1?
    Also, my friend is contemplating buying a Toshiba SD210E (from Paul Taylor in Peterbrogh) can anyone tell me what there experience has been with this player, if it has rgb output and if it has problem playing RCE discs.
    Many thanks!!
  2. Jase
    Jase
    Mar 16, 2001
    9,315
    South Coast
    +827
    Cant help you with the disc, but the Toshiba can output an RGB signal and will play RCE disks via a remote hack (after its been modded).
    There are the relevant hacks posted in the dvd player section.
    cheers
