Making VCDs
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by bikermol, Aug 3, 2002.
  1. bikermol
    bikermol
    I would like to make VCDs of home movies on my PC. I have seen an American Hi8 camcorder. Will the fact that it is not PAL stop me? Now the stupid question, will the footage automatically be mpeg1 or 2. Isee that video editing needs much hard drive space, but I read that a VCD, mpeg1, can be 30 minutes long, with a 700mb CD-R. Thanks for your help, any would be appreciated:confused:
  2. dood
    dood
    Aug 4, 2000
    947
    28
    Hobart
    +38
    all should be answered at vcdhelp.
  3. bikermol
    bikermol
    I'm sorry. Where is VCD help? It sounds just what I need.
    Thank you for your sugestion,dood.:rolleyes:
  4. bikermol
    bikermol
    OK.I found VCD help. Now I will have to lie down for a while. All that info to digest. I've just realised Ive been glued to the screen for nearly 3 hours. Thanks Raj.
