Making Tosh SD220E regionfree
S
Steve Knott
I found a link to a site where you can download a binary file which you can burn to CD then insert in your Tosh220E to make it regionfree - my question is has anybody done this? is it safe?
as I am about to buy a Tosh and can save myself a few quid by buying R2 and making it Regionfree myself.
Link to site as follows:
http://sd220e.chez.tiscali.fr/
Regards
Steve
lentini
Bugger!!!
Now you tell me! I just bought a multi-region tosh an hour ago. :mad: Could've saved myself 25 quid too.
Let me know if it works...
D
Delorian
I'd be extremely skeptical about this, if it was true, surely more ppl would know about it. I've never seen it on these before, and the guys here know a lot.
I just got mine recently and I don't think you save that much by buying it region 2 anyway.
lentini
Region 2 Tosh from Richer Sounds was £119 whereas the MR was £144.
Difference = £25.
Even if my player WAS R2 only, I don't think I'd update the firmware until it was proved to work 100%
S
Steve Knott
HI Delorian
I went into Richer Sounds in Bristol on Monday to buy a Tosh220 Regionfree (out of stock) but the acting manager told me they had R2 220's and they had just got hold of the software to make them Regionfree and they were about to start converting their stock.
I've not spoken to them since but hence the search for this software and my first post on this.
Steve
devastator
What version of the firmware does this give:
my concern is that if I bought a Region2 with Firmware 1.5.. does this downgrade to 1.4 or below??
To find out current firmware press zoom. 6, 0, 6, zoom
Can anybody who has tried updating with this post their results??
enajh2
Did I read this very same post yesterday or am I going mad?!!! :confused:
devastator
You did, didn't get a response... so I thought I'd try again under a thread specifically talking about the 220e. :)
P
Philip Newton
25 quid is not that much to safegaurd against a major meltdown by the DIY route. Plus I am sure it would void any waranty that you have from the dealer. Be safe and pay the extra as I say £25 not that much now is it.
J
Jason S
I'd like to know if this works or not, and if it does RCE etc. So if you buy it and test it, please let us all know
Don't care about macrovision as I can strip it out with the cables.
Why do I want to know....
I bought a multi region version of the 220e from Techtronics 6 months ago, it's been returned 3 times since and still isn't right (last time it came back it wouldn't read R1 discs, sent it back and they've said there's nothing wrong). So short of driving the 200+ miles to their shop and standing over them whilst they check it I think I'm going to have to fix it myself. I'm waiting for it to be returned (courier collected from them today) to see if it's been opened or not.
J
Jason S
my player should be returned on friday, if it's still "defective" I'll give the disc a go since I'm getting no-where with Techtronics.
anothergo
I took a down load from the site mentioned but cant open the file to find out how to make the disc or install, did you have this problems
S
Steve Knott
You need winrar to open this archive file and then you burn the .BIN & .CUE file to disc using Nero - making the disk is easy I just need somebody to try it - so then I can decide wether to get a R2 player or pay the extra to get multiregion.
Steve
anothergo
thanks for the info, have you already burned a disc and if so can I borrow it and I'll install it and let you know if it works. I'll then send it back.
S
Steve Knott
No I haven't created a disk as I don't have a working writer at the moment - sorry
mutley
some people have tryed here in portugal a disk and it worked. i think it's not rce free. not sure
here's the link for the file:
J
Jason S
Use winrar (free/shareware) to extract the files into a folder. Use an app such as Nero, CDRwin or similar to burn from image.
For Nero
Put blank in burner
Launch Nero
File - Burn Image
locate the .cue file & select it
Then hit the write button in the next window.
This then starts the burn process. Depending on your writer anywhere between 1 & 20 mins later your discs ready.
Jason
anothergo
thanks for the info, there are 3 files in the down load and I beleive there are 2 files to be burn using the TAO (tack at once) mode (not sure how to do this), is this right?
J
Jason S
the cue sheet has the necessary info in it, just point nero at the cue sheet and it works out the rest for you. The second file ( .bin) is the actual image file, the cue sheet contains information about lead in / out track length etc.
If you're not 100% comfortable, use a RW disc. You'll only need to use it once anyway so a RW is probably better. My SD220 reads them so shouldn't be a problem.
Jason
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
Latest News
StormAudio launches ISP Core 16 AV processor
  • By Andy Bassett
  • Published
Cabasse launches limited edition Pearl Pelegrina speaker
  • By Andy Bassett
  • Published
AVForums Podcast: 22nd September 2021
  • By Phil Hinton
  • Published
Creative introduces Sound Blaster Katana V2 soundbar
  • By Andy Bassett
  • Published
Audeze introduces reference LCD-5 planar magnetic headphones
  • By Andy Bassett
  • Published
