Making the Sony DCR-TRV340e DVin/out ?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by mmm, Jan 20, 2003.
  1. mmm
    mmm
    Dec 6, 2002
    98
    Kent
    Apparently, there are some camcorders which you can "hack" the eeprom to alter its features. for instance, enable the DVin on a camcorder that has been sold just DVout.
    I own the TRV340e which is a bloomin good camcorder, but it does not have DVin. At the time I bought it - there was no higher spec model. Now Sony have introduced the DCR-TRV355 which has all the features of the 340e but with DVin !!!
    Does anyone know who might be able to determine the differences between the 340e and the 355e models to enable the DVin on the 340e ??
    many thanks
    M
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,514
    Rainham Essex
    +2,515
    The best method to make a cam DV-in enabled is to buy a widget.
    Check the make & model for the correct widget. They can be bought from:
    www.smartdv.co.uk
    www.keene.co.uk
    Mark.
