Making The Plunge-Themescene H30A
Discussion in 'Projectors, Screens & Video Processors' started by Dirk_Diggler, Aug 10, 2005.
  1. Dirk_Diggler
    Dirk_Diggler
    Just purchased it on friday and must say i am amazed by the quality. I see rainbows but don't really care too much about it. I notice it more when i'm tired or i've had a few beers but don't let it bother me too much. What is the best way to connect my basic sky box to it? I've got a component cable going to it but surely i can get a better signal to it than one single cable to the yellow input on the back of the projector. :rolleyes:
  2. n0s
    n0s
    Jun 11, 2005
    173
    16
    Istanbul
    Yeah that single yellow cable (composite) is the worst possible way to wire it, definatley try and use a component wire from sky to it. If the box doesnt have a component output then buy a scart to component adapter, youll notice a diff in quality for sure...
  3. Dirk_Diggler
    Dirk_Diggler
    Where is the cheapest place to get one of these? I need one at 10m long. :confused:
  4. bobbetts
    bobbetts
    Dec 13, 2002
    164
    Norfolk
    Out of interest, will you be connecting any other equipment up (PC, consoles, DVD etc.) as that may influence what cable(s) you need to invest in.
  5. Dirk_Diggler
    Dirk_Diggler
    I have bought a gold plated SVGA cable (10m) which i switch between my DVD Player and PS2 to my projector. My Sky unit won't output to the SVGA.
