Question Making the Most of PC Audio
TheGinjaNinja
Hope someone can guide me here!
I have the following bits of PC kit:
  • MSI X570 Mag Tomahawk Motherboard
  • Sound Blaster ZxR Sound Card (mother and daughter cards)
  • Sound Blaster Crystal Voice microphone
  • RTX 3080 GPU
  • Hyper X headset
  • 2x16GB DDR4-3600 (not sure if relevant!)
  • AMD Ryzen 9 3900X CPU (again, possibly not relevant!)
And the following External Hardware
  • Onkyo 5.1 TX-NR509 AV Receiver
  • 2 x Dali Spektor 1 speakers (used as front left / right)
  • 3 x Tannoy surround speakers (used as centre and rear left / right)
  • 1 x Sub Woofer
I want to get the best possible sound with the kit I have, for music, gaming, movies and video conferences (in that order).
At present, I do not use the onboard sound on my Motherboard at all. I have an optical cable from my sound card to my amp. I prefer not to use the headset - it seems to have great quality but it's mainly to avoid noise when the rest of the household is sleeping!
With this setup, there are different ways I can run audio:
  1. Setting Windows audio device to "Speakers (2 - Sound Blaster ZxR)". When I choose this option, I must also go into Sound Blaster Studio's "Cinematic" tab and choose either Dolby Digital Live or DTS Connect. If I don't do this, the sound doesn't work.
  2. Setting Windows audio device to "Digital Audio (S/PDIF) (2 - Sound Blaster ZxR DbPro)". When I do this, I must then make sure that 'No Encoding' is selected in the cinematic tab on Sound Blaster Studio.
  3. Connect the HDMI of my GPU to my amp, then HDMI from amp to monitor. Set the Windows audio device to "G27Q (NVidia High definition Audio)". Not 100% sure on this as I have never done it. (as an aside, I have 3 monitors: 2 connected to display port and one to HDMI. I could probably use similar option of any of them)
With that background, my questions are:
  1. Which of the methods (1 to 3 above) is best for music (or perhaps another method I haven't listed)?
  2. Which of the methods (1 to 3 above) is best for gaming (or perhaps another method I haven't listed)?
  3. Which of the methods (1 to 3 above) is best for movies / Netflix (or perhaps another method I haven't listed)?
  4. Can you explain the actual difference between options 1 & 2 above?
  5. Is using the optical cable the best solution, or, should I use a wired connection from sound card to amp?
  6. Should I use the sound card at all when I have onboard sound? (sound card was purchased for previous motherboard with terrible onboard sound)
And a bonus question:
  • I'd like to be able to record snippets of music to a file (for example making a music quiz for family during lockdown), and then play these snippets over a Zoom call (for example). I think that probably has something to do with setting my input device in Windows to the "What U Hear" option from Sound Blaster, but I've never managed to get this to work in such a way that it meets my intended purpose. The recording levels are low and when I attempt to play it back over a zoom call, the other people can't hear it. If I understand correctly, I can't really just play over my speakers and let microphone pick it up, the sound software deliberately tries to avoid that kind of feedback loop. How best to achieve my goal?
I think I probably have decent kit but not sure how to use it to it's full capability. The phrase "all the gear and no idea" probably applies here :)
Thanks in advance for any help!
Update 1: After a bit of tinkering, the music sound is better (fuller and more bass) using method 1. I'd still like to understand if this is as expected and why.
next010
By default Windows outputs uncompressed PCM digital audio but not all connections can handle it.
Optical SPDIF = PCM 2.0, Dolby 5.1, DTS 5.1
HDMI =PCM 7.1, Dolby 5.1, Dolby TrueHD 7.1, DTS 5.1, DTS-HD 7.1, Atmos, DTS:X
For the methods 1 & 2
DD Live and DTS Connect are real time transcoders, their purpose is to convert the PCM audio output of Windows into something you can send over digital optical 5.1 or analogue 5.1.
At first I thought you had 1 and 2 swapped around somehow but upon looking at Creatives own suggestion guide this is what they recommend for using optical, you actually leave it on speakers and you don't use the optical output in Windows audio settings - that is very strange to me but your using it correctly the way Creative intended.
For method 3 - This is uncompressed PCM 7.1 digital audio sent right out over the GPU so no quality loss, for this to work you have to connect the GPU HDMI output to the Onkyo TX-NR509 either directly or via a secondary connection using one of the GPU's extra video outputs so your not bound by the AVR for video output.
questions
1 - it shouldn't matter, music is usually just stereo PCM 2.0 so that is fine over optical, I don't know if the Creative audio transcoder converts it, you should check the sound system info when its playing to see if its 2.0 or 5.1
2 - games are usually PCM 5.1 or 7.1 so the transcoder gets you the surround audio from those over optical but at lower bitrate so GPU HDMI would be needed (assuming you can hear the difference in quality).
3 - streaming services are typically just Dolby 5.1, movies on the other hand can be a mix of 5.1 and 7.1 sources so the transcoder converts those too at lower bitrate. If streaming services only optical is fine, if playing BD rips with 7.1 audio if you need GPU HDMI for that.
5 - optical is best since the sound card has no hdmi.
6 - Onboard sound likely wont have a real time DD/DTS 5.1 audio transcoder built in but some media software do have this feature for example Kodi, MPC-HC etc.
For the recording stuff I'm not sure, never dabbled with that. Have a look at this guys tutorials for the audacity recording software, maybe that will do what you need.
EndlessWaves
Dolby Digital Live/DTS Connect are lossy compression so you'd optimally only use them to squeeze surround sound down a low bandwidth S/PDIF connection.
HDMI is the highest capability output so that'd allow you to transmit uncompressed audio, However, that's provided by the graphics card, so your sound card wouldn't have any ability to manipulate it.
TheGinjaNinja
Thanks next010 and EndlessWaves.
I'll experiment with the GPU -> AV via HDMI and report back. I hadn't considered whether the AV receiver can 'keep up' with the frames per second the GPU is kicking out and whether this would impact the G-Sync for video. I can change to run all three monitors over DisplayPort and dedicate the HDMI output of GPU to sound.
As an additional note, SoundBlaster also give me the option of "DTS Neo:pC". When I do this, my AV goes into 'Pure Audio' mode. I'd say it's better quality than method two, but not as good as method one.
A couple of follow-up questions if I may:
1. if the HDMI -> amp (via GPU) is better, am I correct in thinking I no longer really need my sound card?
2. Given most of my music is MP3 or Spotify, is there anything you can suggest to improve quality of playback (other than buying my entire collection again on vinyl!)? I want to avoid cluttering my man-cave with the original CDs as well.
next010
Yes you would lose G-Sync if you send video through the AVR.
If you are out of video ports and by chance have a second PCI-e x16 slot you could get a very low end Nvidia GPU just for its HDMI output.
DTS Neo is a upmixer it turns stereo into 5.1.
1. If your only sending PCM over HDMI then the sound card is redundant.
2. Well this is why you might want to keep the soundcard as it does audio processing, it does have that crystalizer you can mess with for mp3. The AVR would have to have equivlant features for it do the same thing over HDMI.
You could keep both
  • set windows sound output as Nvidia HDMI - this covers games and movies.
  • in music software set Creative speakers as output.
Not all music software might support selecting the audio output but you can override that.
1. Right-click on the speaker icon on your system tray
2. Select open sound settings
3. Scroll down to bottom under 'advanced sound option' select 'app volume and device preferences'.
4. Select Spotiify output as creative speakers.
TheGinjaNinja
Actually, my motherboard has an HDMI out as well. I had assumed it would only work if my CPU had onboard graphics (which it doesn't). Do you think I would get sound over that HDMI out?
(Unable to test at the moment as I would need to order a longer HDMI lead)
next010
You need a Ryzen CPU with built in GPU to use that HDMI, it says so on page 16 of the motherboards manual.
Also any DP to HDMI should work fine too if you have a spare DP output.
JoseSXFIEAX
Hello! your case is like mine. Except that I had the ONKYO TXNR727 without Dolby Atmos support and I changed the ZXR sound card for an AE-9.
My set of speakers are MASS AUDIO 5.1 + 2 speakers for Dolby Atmos (which I installed 3 weeks ago since I also changed the Onkyo for a Denon X4700H that does allow ATMOS).
The question is that when I had the ZXR or AE-9 with the Onkyo without Dolby Atmos I preferred optical sound from the sound card to HDMI sound from the graphics, since I felt that even if it was DDLive or Dts Connect audio, the quality in details, positioning, SBX effects, etc. made me feel a better sound than the HDMI of the graphics. Look, I already know that the HDMI audio comes out uncompressed, but the DSP of the ZXR or AE-9 made me simply SPECTACULAR sound. Examples: Lara's caps in Tomb Raider seemed to be falling off next to me. The most intense shots. The explosions too. Etc.
On the SoundBlaster Command always active gaming SBX the Crystalyzer and bass frequency at 80Hz with gain. The surround for native 5.1 is not necessary and it is a mistake since it should only be used for headphones and that you can get a virtual 5.1 or 7.1.
The same goes for the DTS NEO..it is a virtual 5.1 or 7.1. It makes no sense to use it if you already have native 5.1.
For music the best is stereo 2.1 or 2.0 which is the highest quality it has and also without filters.
With the Onkyo I always left the Dynamic Volume at Low as it gave me more clarity, power and sound details than off.
And the PURE not to mention ... on the front panel of the Onkyo I got the format that I selected in the Soundblaster or DDigital or DTS.
What I do comment now is that with the Denon X4700H I already get the audio from the HDMI because it is the only way to get DOLBT ATMOS and that is already another level that Creative does not have in any of its sound cards unfortunately. Now I do not need the sound card for this very reason. And for games there are more and more PCs compatible with Dolby Atmos such as: Resident Evil 2, RE Village, COD Cops, COD Vanguard, Halo Infinite, Ori and the will of the Wisps, Gears 5, Metro Exodus, Flight Silumulator, etc
By the way comment that my PC is in the same room. That is, I have the desk in the living room next to the TV and Receiver. With which I can easily connect the PC to the Receiver via HDMI. And the sound system that I have for the desktop when I want to play there is the SXFI CARRIER soundbar that has an impressive sound and that also supports Dolby Atmos and also gives away the SXFI TEATHER that has a holographic sound that makes when you listen to them you think you are listening to the sound of your HOMECINEMA. It is BRUTAL !!! I recommend it to you!!
For any questions, I'm here from Barcelona. Greetings!
Sony A84L/A80L BRAVIA XR OLED TV Review - COMPARED to LG C3, Samsung QD-OLED & LG G3
Back
