making panny 5 stand
Discussion in 'Plasma TVs Forum' started by GuitarGray, Jan 7, 2003.
  1. GuitarGray
    GuitarGray
    has anyone made a stand for the panny 42?
    im thinking of it!
    was going to make it out of pine to matck furniture
    18 inch X 1 inch planed timber 42 inch long.. for base cut to nice shape...
    3 X 3 in the middle 40 inches long or so screwed and glued to base .. then drill 2 large holes (unsure on size) glue in 2 dowels to fit up into the plasma screen... coat of varnish and da daaa
    i would also use wire ties to the wall behind for safety
    how does this sound???
    and i am also after dimentions of the real stand ie width lengh and distance from centre hole left to centre of whole on right..
    any ideas or specs will help :)
  2. jont
    jont
    Apr 8, 2002
    4,251
    near Aylesbury
    +550
    If you do a search in this forum there are a few experiences, diagrams, dimensions and photos of home-made stands ...
    rgds
    Jon
  3. jmack
    jmack
    Where can I get a Toshiba/Panasonic stand ,its in this thread
