antellis81
Hi All
I've just had FTTP installed at home and was wondering if I could still use my Q hub
instead of the Linksys Velop unit they have supplied?
I've been quite lucky with the fact that my Q hub and 4 mini boxes all work ok (didn't to start with)
so would really like to keep the current setup if possible as I'm a strong believer in the saying "if it's not broken don't try and fix it"
I tried to follow the online instruction on Sky to plug in from the ONT to port 4 (wan port) but it didn't connect to the internet. is there a setting within the router to change??
Can i stick the Velop Router in Bridge mode and then join the 2 routers via an Ethernet cable??
I have tried to just use the Velop router for all things but i ended up with an angry Wife and Children as the connection kept dropping out,
Thanks in Advance for any help offered
