Making my screen..help please!
Discussion in 'Projectors, Screens & Video Processors' started by martian1, Jan 17, 2005.
  1. martian1
    martian1
    Dec 30, 2001
    2,233
    83
    Sunderland
    +256
    I intend to make a screen from 6mm MDF, i want a 7ft diagonal 16:9 which after looking at projector central and the model projector should work out at
    40.5" high x 72" wide "viewable". Could anyone be kind enough to check this for me. The projector model is an infocus 7200. :smashin:
    I want this made for when it arrives. One other thing if i watch a movie that is a different aspect ratio [but still widescreen] am i right in the opinion that i would get black bars rather than the image overlapping screen....Help :eek:
    Thanks all
  2. Zone
    Zone
    Jun 24, 2001
    6,540
    Barnsley
    +2,141
    Just had a looksy and 84" diagonal works out at 73" wide by 41" high.
    And you are correct re aspect ratio and the projected image, 16:9 material which is actually 1.78 (16 divided by 9 = 1.78) will use all the screen area, 1.85 material will give shallow black bars top and bottom, more widescreen formats 2.35 etc will appear with larger black bars top and bottom, the width of the image will always be the same and will use the full screen width near as damn it.
  3. martian1
    martian1
    Dec 30, 2001
    2,233
    83
    Sunderland
    +256
    :clap: thanks Zone should be fine then :D
  4. MikeRJ
    MikeRJ
    Oct 21, 2004
    226
    Plymouth
    Remember to make an allowance for the borders!
  5. martian1
    martian1
    Dec 30, 2001
    2,233
    83
    Sunderland
    +256
    I will 3" per side thats 1" timber frame and 2" flok tape [nexnix]
