Making MPEG Animations??
Discussion in 'Desktop & Laptop Computers Forum' started by Paul O, Dec 19, 2000.
  1. Paul O
    Paul O
    Nov 2, 2000
    481
    UK
    +21
    Having now mastered the making of Video CDs for my home movies, I quite fancy creating an animated logo for the start of the cassette.
    Thing is, Im a bit stuck as to where to start. Does anyone know of any software which can create these at all?? Paint Shop's Animation Shop looks quite good, but it doesnt look like it saves in a format suitable for Video CD.
    Alternatively, do converters exist to convert to MPEG/AVI from GIF or otherwise?
    Any help would be appreciated!
    Thanks,
    Paul.
  2. Guest
    Correct me if I'm wrong but doesn't Macromedia Flash have the option of saving to MPEGs? Not sure exactly the program you use to make them (Possibly Macromedia Flash or something around that sort of name). Flash makes excellent animations.
  3. Paul O
    Paul O
    Nov 2, 2000
    481
    UK
    +21
    Thanks for the info. Never thought of using MacroMedia, I'll give it a whirl.
    Cheers,
    Paul
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,210
    After Effects is good for this but its a tad expensive.
