Question Making existing hi-fi and speakers into a wireless multiroom system
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Hj31, Nov 20, 2017.
  1. Hj31
    Hj31
    Nov 20, 2017
    2
    London
    Hi there, am hoping someone might have a work round for me. I've got a wired hi fi and speaker system that I love and really don't want to get rid of if I can avoid it, but also really want to be able to make it multiroom by adding a wireless speaker for another room.
    I know I can do this with a Sonos speaker and a Connect Amp but this seems pretty pricey way round - does anyone know a cheaper alternative that still works and sounds good?
    Thanks!
  2. ZootHornRollo
    ZootHornRollo
    Apr 6, 2007
    122
    +4
    1. Have a look at Audio Pro Add-on range and their Link unit that can make your existing hifi part of a multiroom set up.
  3. lmccauley
    lmccauley
    Oct 24, 2000
    3,673
    Newcastle
    +426
    Chromecast Audio is the obvious one. Also look at Yamaha's MusicCast range.
  4. mark363
    mark363
    May 5, 2017
    23
    4
    Leeds
    +11
  5. droidlike
    droidlike
    Aug 21, 2015
    494
    46
    +130
  6. Hj31
    Hj31
    Nov 20, 2017
    2
    London
    Great options, thanks so much - checking them out now!
  7. blackmesa
    blackmesa
    Jun 19, 2007
    2,118
    +85
    Chromecast audio is brilliant, cheap, good quality and you can add them to each room for a multi room setup.
  8. David Hillman
    David Hillman
    Jan 8, 2017
    115
    Illinois
    +12
    Having been a Musiccast user for about two years now, I would have to take some issue with the claim that it's "developing all the time". The most recent "release" -- version 2.40 -- took them five months from May to October and contained exactly one new feature or upgrade. And that feature had almost nothing to do with music ( it was the ability to share custom room photos and settings between multiple phones ).
    At that rate, I won't live to see them fix the actual bugs and issues, like their miserable wireless implementation. None of the bugs that I have reported have seen any action -- like an inability to keep multiroom playback from skipping and stumbling.
    I would recommend Chromecast. I should've gone that route, but I wanted multiroom integrated into devices, not via an adapter.
