Making a projector screen
Discussion in 'Projectors, Screens & Video Processors' started by aylmera, Aug 17, 2004.
  1. aylmera
    aylmera
    Hello. I have heard people mention on this site that a large projection screen can be made relatively easily. Is there a thread stating how to make these, (sorry, but i have tried searching but with no luck. Also, does the quality of the picture suffer when using a homemade screen.
    Thanks for your time
  2. sconie
    sconie
    Aug 2, 2004
    287
    Glasgow
    Check the link below this one on the forums page, lots of details there, I made a topper 7ft by 4ft from blackout cloth, for around £30.
    Good luck
  3. aylmera
    aylmera
  4. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    If you have a look in the FAQ at the top of this forum you'll find links with very good instructions on how to make a fixed screen with blackout lining - shouldn't cost you much more than £20-ish. As for performance, it's not quite as good as using proper screen material from the likes of Harkness Hall or DRH, but it's a very decent job.
    There's also info in the Screens forum, as Sconie says.
    Sean G.
