making a playlist
Discussion in 'Headphones, Earphones & Portable Music' started by JJ VDUB, Jun 11, 2005.
  1. JJ VDUB
    JJ VDUB
    how do I make a playlist from existing tracks on my HD3. I cannot seem to do it. the only thing seems to be the 'compilation album' which would meen duplicating tracks on my player. not been getting very far with the SS help and manual..
    thanks guys..\
    JJ
  2. Simebaby
    Simebaby
    Sep 17, 2004
    769
    +21
    I could be wrong, but I don't think the HD3 supports playlists - it uses "groups", which might be the same as the compilation thing you've described. I think playlist support started with the HD5.
