Making a DVD from DV camcorder
Discussion in 'Blu-ray & DVD Players & Recorders' started by ketank, Aug 22, 2005.
  1. ketank
    Hi guys,
    Would someone be able to explain the difference between making a dvd via a DV camcorder from DVD recorder and a PC.
    the reason why i ask is:
    I have a dV camcorder which i take everywhere & make the odd family movie, i have been using my PC to make a dvd. the problems i have been facing is that:
    1. it takes HOURS to do
    2. i can fit only 1hr 20 min of avi footage
    3. its a hassel...
    So if i'm correct in my research is this correct:?
    I'm hoping to capture footage & edit on my PC and then save it back to the DV camcorder and then with the DVD recorder........ make a dvd and i can fit between 2 and 4 hours....
    Be grateful of any help
