hiphopapotamus
Hi there
I currently have a monitor which is 3440x1440 resolution and runs at 144Hz. I use a displayport to usb c cable to my laptop to run it at the moment. I believe that's display port alt mode. The cable also has an in-line usb c socket so I can inject power.
I just need a few USBs and ethernet also, but want to turn the monitor into a single cable solution as a juggle a few laptops.
If I plug my displayport to usb c cable into a hub with a usb c data port, will it pass through and allow me to still run my monitor at full resolution and refresh rate?
I cant find any info on how to do this
My machines don't have thunderbolt and I don't want to spend lots anyway as the monitor was £350
Any suggestions appreciated
