Major probelm with Pio 435XDE - HELP!!
Discussion in 'Plasma TVs' started by Buck37, Jan 15, 2005.
  1. Buck37
    Buck37
    Dec 28, 2004
    63
    Yestreday (Friday 14th Jan) had my new Pio 435XDE delivered and installed.
    Unfortunately Freeview reception poor in my area therefore have to rely on Sky and was fearing the worst, however considering its just out of the box and not bedded in I am delighted with the PQ on some (not all) of the channels.
    DVD through my Samsung 945 (HDMI) is phenominal, especially consdiering the machines price.
    Now, everything was going sweet until I noticed a blue line that created a shadow flickering in the bottom left of the screen, its appearence was intemittent and appeared on all inputs, however was always there when I connected my laptop.
    The band about and 1 inch wide by 4 inches tall creates a duplicate shadow and flickers on and off but not all the time........very annoying and worrying.
    I would be interetsed to know if anybody else has had this problem.
    I will contact the retailer Monday and insist on a screen replacement as this cannot be right, however if the solution is simple then I would rather not have to do this.
    Such a same to dampen the day..............but boy what a looker!!!!! when everything is ok that is!!
    Feedback appreciated.
    Mike
  2. jwramsay
    jwramsay
    Sep 7, 2004
    1,622
    West of Scotland
    +70
    Does sound faulty, never seen such behaviour on my 434.
    Glad to hear that the Sammy 945 is a good un.
  3. rdt123
    rdt123
    Dec 14, 2002
    1,415
    Busting out a restaraunt in Queens, NY
    +33
    I have seen a band of blue on the bottom left which appears fora second when i switch hdmi from 720p to 1080i. It vanshies instantly when the dvd begins to play again. I thought it was the player but i'm not sure. I've never seen it veiwing any sources
    Rob
  4. VIK AD
    VIK AD
    The DVB channels don't work anymore.
    They used to when I intially set up the 435XDE. No idea what went wrong. I have not made any changes - you know the saying, if it ain't broke, don't try to fix it!
    All other features work 100%
    Any ideas please?
    Thanks,
    Vik
