Mains switching for power amp fed by Processor
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by lardy, Mar 14, 2006.
  1. lardy
    lardy
    Jan 4, 2004
    96
    Coventry
    Hi all
    I've just bought a musical fidelity "can" style power amp for my front channel amplification and am looking for a way of switching it on and off "in concert" with my Yamaha DSP-AX series processor (without my other half having to reach around the back to the on/off rocker switch each time).
    The power amp needs about 150W and an earth so the power outlets on the Yammie are not suitable.
    I recall an email from Maplin advertising a trailing power outlet for PCs that was switched such that if the PC was off the other sockets were off too. Anyone used/heard of this or know of another solution that is wife/SOH friendly??
    thanks
    ian
    edit, found it but gone up in price:
    http://www.maplin.co.uk/Search.aspx?criteria=L22BK&DOY=14m3
    or http://www.oneclickpower.co.uk/home.htm
    any other suggestions?
    probably the best solution, see:
    http://www.pcpro.co.uk/reviews/7165...ins-panel.html?searchString=oneclick+oneclick
  2. clockworks
    clockworks
    Dec 7, 2005
    3,573
    West Country
    +297
    The cheapest way to do this is to plug all the components into a trailing lead, and switch the whole lot on and off at the wall.
    I thought that the MF amps were auto-switching - don't they go into standby if no input is detected for several minutes? Maybe I'm getting mixed up with some different amps.
  3. lardy
    lardy
    Jan 4, 2004
    96
    Coventry
    thanks, I'll check that out - reaching around the back of a 36" TV is not really an option for the missus.............and I'd rather not leave in standby all the time as I'm tight.. :D
  4. lardy
    lardy
    Jan 4, 2004
    96
    Coventry
    ah ha - did manage to buy one of them there leads and it works fine *most of the time* - do get the odd day when nothing comes on with my new setup of 3 x X-A50s and a X-A2 (bi-amped with 2 of them).
    Oddly enough there was a Powergen offer in the last leccie bill for 3-way adapters that do the PC switching job - wonder if they do power amps as well - as they are only £9 (special offer)........??
