  • Black Friday Deals
    Visit our Black Friday page for our frequently updated, hand picked deals on TVs and other tech.
Mains power lead for TV
Paul97
We have just purchased a new 60" TV and hung it on the wall and the better half wanted all the visible cables bundled together so it looked neater. I'm sure the power cable has had some affect on the picture quality, would I be right and is there a reasonable priced shielded power lead I could buy.
Paul
Rock Danger
No. The cable will not affect the quality at all unless it's damaged, leaving you with no picture.
£5 from eBay or make one yourself from b&q.
Paul97
Thanks for the reply Rock Danger, when you say "make one yourself from b&q" are you talking about standard cable?
Paul
Rock Danger
Paul
Hey Paul,
Yep just 2 or 3 core mains cable with an IEC connector. If you wanna be fancy you could put on a ferrite core ring closer to the TV end of it, but typically mains cables are basic made in china standard mains core that you'd get on your kettle, hence the term 'kettle lead'
The only important thing is that the cable is thick enough to bear the load of a TV (bout 300w) and you fuse it with whatever it has in it now (probably 5-10 amp)
I have to do the same thing as you for my new projector, it's 3 grand something and I'll probably just make it up myself. If someone tries to sell or convince you of a fancy mains cable giving a better picture, reach out and slap them.
westie86
Paul
Yes I got one off Amazon think it was about £20
Did you not read the earlier replies (which were accepted as being helpful by the OP) that a screened mains cable is pointless; and that suggestions that it is necessary to pay more than about £5 for a suitable cable should be treated with derision ?
westie86
No I didn't read them.
