So how come Belkin give an unlimited equipment replacement guarentee for the surge protectors I have?
Well, I'd be quite happy to give you an unlimited guarentee that your AV equipment will not be stolen by space aliens...
I do know of people that have had equipment killed by surges until they installed these particular versions of 'snake oil'.
How do you know that was the cause of the equipment's demise? The only such cases I am
sure about were multiple failures caused by lightening induced surges of a magnitude that would most definitely not be absorbed by the tiny MOVs built into a trailing socket surge suppressor.
I did spend some time trying to research the usefulness of surge suppressors, with depressingly inconclusive results. I am not prepared to state categorically that they are pointless, but I am inclined to believe that, and so I do not use them myself.
Actually, that's not quite true. I did buy one once (before I did any research). However, it claims not to be functioning any more - the poor thing has clearly sacrificed itself to save my PC, as indicated by the non illumination of the "protected" light. This happened several years ago. Ungraciously, I haven't bothered to replace it, because I now believe that the cheap components within it are so inadequately specified that they will inevitably fail long before anything I'm likely to connect to it.
But I could be wrong.
