They are known as IEC leads, pr amins leads with an IEC connector.
A kettle type can safely also be used with PC or AV equipment.
The reverse is not always true; a kettle draws about 10 Amps and a kettle lead will be rated / constructed with this in mind whereas PC and A/V equipment tends not to draw more than 2 or 3 amps.
Other than that no big difference although you can also buy IEC leads with built in surge protection or RF/EMI filtering.
Chris Muriel, Manchester
You're opening a whole can of worms there, so please do a search. Mains cables thread inevitably end in tears. If you fancy trying one, with an option to sending it back if you see/hear no difference try cleareraudio. MarkGrant also makes some that are very well made but no money back guarantee as far as I know.
So, rather than generate another thread that will go round in circles, try one for yourself.
I no what you mean it has the Hdmi Debait all over it![]()
"Cry havoc and let slip the dogs of war!"
I would say that a very cheap lead may have poor quality contacts, something to bare in mind.
I have always wondered this, especially when you read magazines/reviews claiming them to be super amazing and you shouldn't be without one! One day I might buy one for the sake of it just to see if there is a slight difference![]()
I'm firmly in the skeptics camp, but for an alternative view on the value of blind testing read here:
Blind Listening Tests are Flawed: An Editorial | AV Guide
Apologies if it's already been posted elsewhere.
(I'm not necessarily supporting this, but it's an interesting POV)
So, if I ask my kids what sounds better, they're partisan hacks or just me?Most such tests [...] are performed [...] by partisan hacks on a mission to discredit audiophiles.
Hello Dave,
Anything can be returned for refund
Hardly anyone returns anything though.
And I agree, the only way to be sure is to try and make your own opinions.
Mark.
