Mains hum with Rega Planar 3!!
Discussion in 'Hi-Fi Stereo Systems & Separates' started by morb666, Aug 8, 2005.
  1. morb666
    morb666
    Oct 21, 2004
    312
    King's Lynn
    +8
    My Rega deck seems to have developed a humming problem, when the arm is parked then everything is quiet but if you swing the arm over the platter mains hum can be heard increasing in volume towards the center of the platter!!!! Any ideas how to cure this???
    Thanks,
    Morb666
  2. Londondecca
    Londondecca
    Dec 21, 2003
    2,082
    +96
    I would check the earth wire to the amp is nice and secure
  3. morb666
    morb666
    Oct 21, 2004
    312
    King's Lynn
    +8
    Well, I moved the deck further away from the Amp and problem solved. Odd that it's decided to be a problem now after a couple of years with no problems!! Nevermind at least it's easy to solve with just a bit of judicious seperates placement.
    Cheers,
    Morb666
