Mains hum with Cambridge Audio Azur 640C
Discussion in 'Hi-Fi Stereo Systems & Separates' started by harmonica98, Dec 30, 2004.
  1. harmonica98
    harmonica98
    Dec 30, 2004
    239
    28
    +24
    Hi folks
    I've just purchased the above player from Richer Sounds. While I am very happy with the sound, the mains hum does seem very loud compared to other separate CD players I have experienced - is this normal? I didn't have the plug completely in at first which resulted in an extremely loud hum - I have fixed that now but the hum is still very much present. It is not noticeable when playing CDs, but is a little annoying even so.
    Is this just a fact of life with this model, or might I have a duff player?
    Any input gratefully received.
    Tom
  2. Ovation
    Ovation
    I'd go back and have it looked at. You're well within the time limit for that.
  3. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,966
    2
    +3,338
    The last consignment of transformers seems to have been slightly louder than the earlier ones but a simple circuit breaker (the ones that stop you killing yourself when mowing the lawn) can often help.
