mains filter/conditioner
peve3
hi there just a quick question, In the new what hi fi they say a mains filter makes a big diffrence to the picture!!
Is this tru ?
J
juboy
This question could well start a very long, boring and possibly heated thread comprised of 50% of people saying 'Yes' and 50% saying 'No'.
My advice, and really the only sensible option, would be for you to arrange a money-back guaratee trial with the seller/maker of the item you wish to buy and prove it to yourself... either way.
J
jim.rae
These guys live in a different world from you and me.
They promote speaker cable and stands the price of a small car, SCART leads that are worth more than the average HiFi system etc etc.
If you are in your twenties, are teetotal, have perfect hearing and have a sound proof room, you just might - maybe hear a difference.
It's the same with TV pictures - using good RGB or component sources will give you great pictures on a good TV.
But a mains filter will may not one jot of difference unless there is a specific local problem with the mains supply.
The TV's transformer and control systems sort out most routine issues unless the voltage falls below 220 volts.
Now a spike protector is a different thing entirely and I would recommend them - less than £10 if you shop around.
As for me with traffic noise outside, the phone going, my PC running and a glass of red wine just poured - I'll take my chances on a cheap lead and power supply!
J
juboy
Jim - you and I would appear to agree wholeheartedly on this point. It's something I've been saying for a while now. Fundamental external factors, over which you generally have little or no control, have a far greater effect on your listening/viewing perception than any cable or lead.
MartinImber
Established Member
A mains filtered socket can cut out a lot of impulse interfearance on DTTV
J
jim.rae
As I said, I recommend a cheap surge protector - they had them yesterday in my local cash and carry at £5 - a bit more in Woolworths.
That stops any DTT interference from fridges, light switches etc for me.
Cool-hand
What happened to the 20% rule? After you've bought your equipment at least 20% of the total value of your kit should be spent on hookers!!!
⭐ Philips OLED+908 TV preview + Avid Accent amplifier reviews + Hi-Fi & AV News
Back
