Mains Cable for ROTEL RMB-1075 Amplifier?
Discussion in 'Cables & Switches' started by daverob, Jun 20, 2005.
  1. daverob
    daverob
    Nov 7, 2004
    211
    +3
    Would like to replace the mains cable supplied for my ROTEL-RMB 1075 amplifier. Have been looking through the Russ Andrews/and other web sites for information, but still remain confused as to the "way forward". Will a more expensive cable (£80 - 120) make a real difference to sound quality etc. If so, which type/manufacturer should I research? Appreciate such a question can be very subjective, however, any help you can give would be VERY MUCH APPRECIATED. THANKS!!!! :)
  2. Londondecca
    Londondecca
    Dec 21, 2003
    2,080
    +96
    The cheapest way to find out is to find a dealer who will loan you a cable
